94 superjet heat temp removal (limp mode)
Hello, sorry to post this after seeing it many times but I’m still not sure on a definite answer on how to remove the temp sensor. Some say to cut it i there’s way to open Ebox and unplug? What is better? And if you do cut where do you cut? Is it the black wire that’s got the sensor on one side and then goes into ebox? I need/want to remove or unplug because my ski is in limp mode. Thank you!
dfw
You can cut the sensor off and it will run as long as the wires aren't touching each other. The box will need to be opened in order to unplug it.
