I just picked up my 1st Yamaha Superjet. I've always had Kawsakis and still have a X2, so the Yamahas are new to me. The ski is bone stock.
Can someone tell me the stock screw settings (turns out) and jet sizes for the low and high jets and spring/needle combo. I just need a starting place to tune from and I couldnt find anything using search for a stock setup.
The ski runs OK when cold, but when I fall off or stop in the water for awhile to talk to someone it won't start again. When I pull the plugs they are wet with fuel. If I let the ski sit overnight it will fire up again.
I have 165-170 PSI compression, have spark, and fuel (wont fire even using primer).
Thanks in advance,
Ed
Thanks in advance,
Ed
