- lincoln nebraska
i have a 90 superjet and it was not running right, seemed like it was sucking air from somewhere so i went through the fuel lines, the carburator and carb gaskets and the hole bit. well the last time i tried to start it it fired right up ran rough and i heard a pop, ting and it wouldnt do anything from there. sounded like the battery was drained cus all it would do was make a click noise. it had a brand new battery and i went to change the starter because it was cranking slow. well went and started unbolting the starter and there was a hole about quarter size in the bottom of the block and a crack right next to the starter and a crack just above the driveshaft of whatever it would be called. any input on wat would cause this? also it was a j650 b motor, and i have another bottom end from a 701, so what wouldi need to do to convert to a 700? i know i need pistons, and bore the walls, what else would be needed? thanks
