Since owning this ski the kill switch never worked, the previous owner just set the idle low so it wouldn't idle. I just re jetted the carbs and reinstalled. I fired it up and it reved up very high without my help, then I panicked and disconnected the battery completely, and it stayed running, so then I pulled the plug wires and that killed it. I realized I had the idle screw too high, so I backed it all the way out so it wasn't touching anything and tried it again. I was thinking by backing the idle screw all the way out, the engine would die, just like it used to. But, it just idled, lower this time, but it wouldn't die unless I pulled the plug wires. Do I have an air leak somewhere ?
