SX/SXi/SXi Pro 750sx ebox issue
I finally got around to finishing my 750/650 build tonight with a freshly rebuilt engine. I ran it for a few seconds to see if it worked and then the ebox(mounted with straps in the back of the hull) touched the engine due to the vibration and there was a spark as they touched. Instantly after that it sounded like the engine revved up and i hit the stop button. I am not entirely sure whether it stopped as i hit the button or because of something else.
Now the engine will not even start, no click or any sound. It rotates over by hand and the battery is normal so it is some sort of electrical issue.
Could it just be the fuse or the starter solenoid? I have not run tests or checked anything but will tomorrow
Most importantly, is there anyway i could prevent a issue like this, like run a ground wire from the ebox to the engine block?
Thanks for any help in advance.
