701PILOT HOW TO VIDS
brisbane
701 AUS Pilot luke Rotolone is putting together some instructional Videos to give you some insight on how to pull off some freestyle tricks. Here is his first explaining the barrel roll. He makes it look easy.
SWFL
Thanks for the video...so let me see if I am seeing it correctly...he approaches the wave with the wave to his left. He leans slightly right to get some momentum and then swings his whole body and the ski back left, over the top of the wave...is this correct? Sorry it happens so fast I'm not sure if I'm watching it right!
Glad you guys like the video. I'll be trying to post a new video each week so keep an eye out.
Basically when rolling you want to head straight at the wave. You can do a bit of a S turn before hitting the wave but it's not necessary. Basically the S turn just speeds up your rotation and helps you get around but it makes your roll smaller with not as much height.. When you want to make your rolls higher you want to head straight at the wave and as you are at the bottom of the wave you need to turn full lock, throw your head over and look down at the water showed in the video and give it full gas, hold on tight and look for your landing.
Don't be scared of it. Just don't let go and you'll be safe.
brisbane
New breakdown Video from 701 Pilot Luke Rotolone. Luke is doing these crazy instructional Videos for all the Blaster guys that want to be Surf free-riders. Makes you want to go and practice. Enjoy
