701 stock bore
whats 701 stock bore and how much can it be bored to? my 96 blaster needs new pistons cause they go jacked so should i have the cylinders bored at a machine shop then order pistons? never done a rebuild so any info would be greatly appreciated thanks
Stock bore is 81mm. Not sure what cylinder that 96 is...I think that's a 62T. I believe you can take that up to 86mm.
If it's a 61x cyl, max safe bore is "supposedly" 84mm. Some builders question that, some don't.
