701 engine bugs
D
Dski
Guest
Ok, been having a few problems with an SJ i bought. i had a water leak from bad head o-ring. I put new o-rings in.. and put it in the lake this Saturday.. it ran great for about 15 mins and then same problem of one cylinder seeming like it was cutting out.. I immediately shut it down and brought it to the dock. Pulled the plugs and one was bone dry and the other was wet. Are they supposed to be wet or dry? I have a MSD TL model 4270. could it be bad coil?
I run dual buckshot carbs and i thought one of them might be bad causing no fuel to one cylinder. but the two cylinders share the combined gas from both carbs(is this correct?)
even if they share a single fuel pump, one cylinder could be starving due to lack of fuel due to clogged jets or clogged internal fuel filter.
are you getting a good spark on both plugs?
the bad ring on the head..... whats up with that? is the dome fitting loose in the headshell?
D
Dski
Guest
well the o-ring looked like it was seated incorrectly ontop of the poly-seal. so hopfully I straightened that out. both plugs were definitly firing during first 15 mins or riding.. then im not sure if im losing spark or losing fuel. it seems to be an intermittant problem. i thought one of the spark plugs being dry and one being wet might lead to some clues.
