6m6 top with a 61X bottom ?
Boris
The Good Old Days
Here I am, waiting for Chucky to finish my motor. As it is the flat part of the year I'm getting kind of restless and the mind is wondering.
I have a perfectly running 650 with 175psi in each hole and a pro-tec pipe. The thing runs great, one day it was going to be my back up motor.
On the bench I have a nice set of 61X cases that were meant for a "Frankenstein" project but I don't feel like spending money to clean up my 62T 760 cylinder.
So I started thinking of making a "Mongoloid Frankenstein" by wrapping my perfectly good 650 with some 61X cases.
Anyone ever try this ?
Any gains in just a case swap ?
Is it worth the effort ?
Again, this is all due to flat water blues so if I should quit screwing up a good motor and wait for Chucky than let me know.
:smile:
There's your answer. :biggthumpup:
Honestly, I think that you will not gain anything. The ports on the 650 are tiny (all of them). The cases aren't restricting the motor.
Boris
The Good Old Days
So no gain in the cases, huh ?
Crap !
I do have a freshly Chucky bored and ported 61X top end and a nifty Riva head that is waiting for the T-cases, b-pipe and dual 46mm intake setup .
hmm,............................
This waiting thing is killing me and I do have a 6m6 to experiment with.
EvanB85
Team Poseur
Tacoma, WA, USA
No expert am I, but I would say a reliable protec'ed 650 is going to do just fine for now. The cases would make very minimal difference, if not a negative effect.
FWIW, Phill is running a 62T bottom with dual 38's and a 6M6 bored out to 717cc.
I will not be associated with that asshat project in any way.
Boris
The Good Old Days
Hey misster, who ported it and whoss idea wass it ?? :18:
Does it run ?
Ill these reports that there is a big difference between the X and T cases got me thinking that's all.
It would be rather stupid to tare down a perfectly good little motor only to come up with and abortion.
Maybe I should just stick a rusty crank into those cases, dig up some dingy pistons for my 760 cylinder and see what grenades first.
Maybe we should have a blow off at Daytona.
:lmao:
To make matters even more interesting with this motor: When we first assembled it, we used a shaved stock 701 head to increase compression a bit.
I didn't take into consideration that the ports on the 6M6 are a bit lower, so there is more volume to compress after port closing.
That thing blew 215psi with a good battery. :haha: :haha: :haha:
Now we got a completely stock 701 head and about 180 psi.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Boris, I hope to finish next week, I have been chugging along on getting your lower end finished! I'll ring you at the beginning of the week.
The old stuff I did back in the day was I used 6m6 cases and a 701 cylinder, hit really good with the smaller 650 intake with the smaller reeds.
Boris
The Good Old Days
Chuck, I'm not trying to rush you at all.
I'm just bored right now and have a choice,
1- destroy a perfectly good 650
2- cut my hull up and modify
Variant 1 looked like more fun with the potential for fireworks. :bananajump:
I really don't want to use that 701 top end until all the rest is done hence the Mongoloid Frankenstein.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
Boris,
Ive asked about this before,
and the feedback I got was that it makes a difference, IF your 650 cylinder is ported, or you have other 'air moving' mods ( pipe and such)
I plan to slap my sons next engine together in a similar fashion, in fact i was porting the 650 cylinder tonight, it will go on 61x cases.
Boris
The Good Old Days
The thing does have a pipe but I doubt it has any porting done.
Could take care of that while the motor is apart.
I guess when and if I pull this thing apart I can better compare my x cylinder and the 6m6. Could try to open up the 6m6 ports to match or be close to those of the X.
Than again, I could just pull out the crank, stick it into the x cases and clean up the T cylinder.
I loved playing with LEGO when I was a kid.
The stock port matchup of the 6M6 cylinder is actually pretty damn good compared to the X cylinder.
But it would take quite a bit of work to get the ports the same size as an X cylinder.
keefer
T1
Tennessee
Back in the 90's there were a couple of these setups in our riding group. I built one of them, and they ran well compared to the 650. We were running 180ish compression with a good exh system and stock ignitions. They did have a good hit and we thought we were doing something trick at the time. Ahhh, the good old days.
WaveDemon
Not Dead - Notable Member
Hell, Florida
hmm very interesting. I gots some 650's kicking around.
