They should all be the same bolt pattern.
You're doing it wrong. :biggrin:
That's always a big possibility, but not today. I got my engine about two weeks ago and UPS had beat the package pretty good. I took lots of pic of the package condition before opening and of all the hardware inside. I bought a short block with carbs/intake. The pulse nipple was busted off but that was the worst thing I could pick up on until this.....
I took a step back to really look at the cases and see why the flywheel cover wouldn't fit. All the bolt holes liine up except for the one on bottom between the driveshaft and the bendix. It looks as though the cases were bent about a 1/16-1/8" upward. I can't get an OEM (or anyother FW cover) to fit this bolt hole. There might be a slight, hairline crack on the cases below the crank in what would be the area under the stator. I can't see anything that goes through and through, and it's very slight but since the FW cover problem I went over it with a fine comb. I'm not sure if it's a paint defect or truely a crack. I'll have my riding buds eyeball it too.
You guys think if UPS dropped the package it could bend this area without breaking it? I have $5K insurance on it so i'm thinking of going to them. Bad phone pics, but you can see what's what.
