- Wilmington, North Carolina
I'm toying around the idea of putting a 900 or 1100 zxi engine in my 650sx. Just wondering if anyone else has done this and what it took to do so, or if it's just a bad idea b/c of the weight transfer. Also, i know there are plenty of 1100 x2 build threads out there to get info from as I searched around to know that i would need to do something with the driveshaft, either lengthen the stock one or shorten a x2 shaft, but i am not sure as it is probably just a little different than the x2. A engine side coupler from a 900 if using a 1100 engine. And for a bed plate i have seen Rad Dudes offers one or you can just mod a stock bed plate. I noticed the big issue was that with the 1100's, the exhaust either hit the hull and you would need some 900 exhaust parts. On Special FX's build thread, he used a 900 and a B-pipe with a adapter which seemed to worke great, and seemed to be a pretty straight forward install. The engine that is currently in my ski is a PJS viper 9000. How much more improvement would I see? I have a 300sx that i would like to put that PJS engine into as the thought of either of the two bigger engines would be to much weight? correct me if i am wrong b/c i am somewhat new to to most of this but i still can find my way around a ski. Thanks for any info.
