300/440/550 650sx problems
chrisdoc0608
insulting
rocky mount, nc
newb here to x-h20.. ive been having some serious issues with my 88 650sx these last few days. starting with it cutting out at full throttle here is the link to the begining of my troubles http://www.pwctoday.com/showthread.php?t=113248 as you can see i thought that i had it fixed, it ran great the rest of the day and for 30min the following day. then when i took it out yesterday it started again so here is the link to what is going on now... http://www.pwctoday.com/showthread.php?t=113559 so that is where i am now and i really want this thing fixed soon so i can go riding this week.
Thanks alot, Chris
cookerq62
Life's Been Good
Upper Bucks, PA
I had the same problem with my sj. It turned out to be the stator wires were cracked and brittle. I sometimes had spark and sometimes didn't. It would also cut out blasting through chop. I was chasing my tail trying to figure it out cus everything checked out ok on a multi meter. It finally gave out at the rager after a flat landing. When I pulled the stator this winter the wires on 2 of the coils were broken. I ended up sending it to Jet Ski Solutions and getting it redone.
chrisdoc0608
insulting
rocky mount, nc
ok well that could explain the cutting out at full throttle in chop, but now the damn thing will not idle, i turned the low speed out 1/4 turn and it started up and ran at idle, then just a little while ago i went to do it and it didnt start again!!! i cant figure it out and i am starting to get really pissed. i pulled the plugs and grounded them out on the head and they were both getting spark......... so what next? o btw the exhaust lets out a poping/puff sound that is like built up pressure after a few times turning over, almost as if it is releasing presure when the pistons fire built up fuel in the cylinder.
cookerq62
Life's Been Good
Upper Bucks, PA
What do your plugs look like? They should be dry. If they have milky white stuff on them its a water leak some where. If they are just wet with fuel you prob have bad spark. The puff's coming out the exhaust sound like unburnt fuel getting lit off in the water box. Try cutting back your plug wires and changing the plugs. Also pull off your flame arrestor and use a can of starting fluid to get it running. If the ski has good spark and isn't flooded it will have no prob starting. Just be careful if you have converted the ski to premix as starting fluid doesn't have any oil in it. If it runs on the ether then dies when you pull the gas you prob have water in you tank.
chrisdoc0608
insulting
rocky mount, nc
thankyou..... im actually abt to empty the tank out, i did all of the things that you listed last night while i was tinkering with it. the plugs were dry except when i flooded it, then they were wet with fuel, no milky white stuff thank god lol... i started it up this morning and it ran fine at idle... im starting to think that is may be bad gas:aargh4: ... i am just gonna hold off messing with nething else until i put the westcoast head on that i am going to pick up this afternoon. as far as water i just pulled the exhaust out and checked all of the cooling lines, they are in good shape with nothing abstructing them, so hopefully i will have this solved soon. but if anyone else has any feedback on the whole situation please feel free to let me know.
Thanks, Chris
chrisdoc0608
insulting
rocky mount, nc
ok i checked the cdi, stator, and regulator with a multimeter i compared it to the specs that i got off of pwctoday, here were the results:
Black Red (Negative multimeter lead) to:
Black Yellow: 500,000 ---> ∞ Ω 280
Black: ∞ Ω 4000
Blue: 500,000 ---> ∞ Ω 3000
Black Yellow (Negative multimeter lead) to:
Black Red: 3000-6000 Ω 100
Black: ∞ Ω 4000
Blue: 0 Ω 0
Black (Negative multimeter lead) to:
Black Red: 15,000-25,000 ---> 50,000-100,000 Ω 2000
Black Yellow: 15,000-25,000 ---> 50,000-100,000 Ω 2000
Blue: 15,000-25,000 ---> 50,000-100,000 Ω 2000
Blue (Negative multimeter lead) to:
Black Yellow: 0 Ω 0
Black: ∞ Ω 2000
STATOR SPECS AND TEST
Charging coil output (Yellow to Yellow): 38V AC
Yellow: 1.5-2.3 Ω 2.3
Black: 0.7-1.3 Ω 1
REGULATOR/RECTIFIER TEST
White (Negative multimeter lead) to:
Black: ∞ Ω 1.5
Yellow1: ∞ Ω 5
Yellow2: ∞ Ω 5
White: ∞ Ω 4
Yellow1: ∞ Ω .5
Yellow2: ∞ Ω .2
Yellow1 (Negative multimeter lead) to:
White: 1000-5000 Ω 5
Black: 2000-10,000 Ω .5
Yellow2: ∞ Ω 2
Yellow2 (Negative multimeter lead) to:
White: 1000-5000 Ω 4.5
Black: 2000-10,000Ω .5
Yellow1: ∞ Ω 2
it looks to me that i need a new cdi and a regulator what do u think?
cookerq62
Life's Been Good
Upper Bucks, PA
You Should Considder Sending The Elec. System To Jet Ski Solutions. He Does And Awesome Job And Won't Replace Anything That Doesn't Need To Be. Plus He Will Give You A Good Discount If You Send The Whole Thing.
