- Charlotte, NC
Ski cut off a few weeks back, here's what's going on:
-Good compression at 150psi per cylinder
-tried 3 different cdi's, no go
-ordered/installed a new stator, ended up being a 4 wire instead of a 5 wire, wired it in correctly (purple to blk/red), stator is set to factory marks
-installed a known good flywheel
Spark is strong after this, but still won't run. Hit the primer a few times and seemed like the engine wanted to kick backwards?? Seemed like pre ignition. I removed the flywheel and found that the key sheared. Cleaned it up, installed a new key and it again it was cranking and it kicked back and completely stopped the starter like it was firing way out of time. I removed the flywheel again but this time the key was intact, but looked like it was about to go. I just don't understand why it's doing this. Has anyone ever seen this?
