i need the resistance specs for the stator on a 62t motor.
chrisdoc0608 insulting Location rocky mount, nc Jul 2, 2007 #1 i need the resistance specs for the stator on a 62t motor.
kurtwolff Location Mooresville, NC Jul 2, 2007 #2 I believe the specs are in the Tech FAQ section, I know they are on the site. Do a search and you will find 'em.
chrisdoc0608 insulting Location rocky mount, nc Jul 2, 2007 #3 i got them here http://www.pwctoday.com/showthread.php?t=124615 the ones in the tech area dont match the color wires i have.... dunno
Matt_E steals hub caps from cars Site Supporter Location at peace Jul 3, 2007 #4 Green-Green 1.05-1.15 Ohms, OC to ground. Red/White to GND 15 Ohms +10% Brown/White to GND 350ish Ohms.
Matt_E steals hub caps from cars Site Supporter Location at peace Jul 3, 2007 #6 What do you mean? Exactly from the OEM Manual: Charge coil (Brown/white to GND) - 497.7 - 608.3 Ohms (at 68 Deg F) Pulser coil (Red / white to GND) - 12.6-15.4 Ohms ( at 68 Deg F) Lighting coil (green to green) - 1.14 - 1.40 Ohms ( at 68 Deg F)
chrisdoc0608 insulting Location rocky mount, nc Jul 3, 2007 #7 i mean your first post said 350 ohms for the chraging coil, that was throwing me off
