- Waterford, Michigan
So I just tryed to upload a picture for about an hour from my phone tobad im terrible with computers..
Anyways i have a 61X dual R&D intake and my only problem is they are REAL close together..
I got the longer shaft in and mounted them just fine after some chopping and now my only problem is the back carbs Return and inlet are just about touching the other carb and i wont be able to get fuel lines on them without pinching them..
SO im down to looking for 90 degree fuel fittings for one of my 44s and its a bitch and to top it off they are two different sizes the return is slightly bigger then the inlet
ANDD they are pressed in.
Im sure sombodys ran into this problem before can you tell me what you did how you did it where to get the fuel fittings etc etc
also maybe sombodys can throw out the jetting sizes for me that would be tits
thanks
thanks
