Have you moved anything in the engine area or adjusted the steering cable lately?
There are rubber blocks on the inside of the hull that hold the steering in place, make sure the steering cable is snapped into the the rubber blocks.
Make sure the pump is centered when the bars are centered. If its not, the snap end of the cable that hooks to the ball on the turn plate is adjustable, so youc an adjust it accordingly.
