#0 thanks for the input,but can you really push the piston up to the where you can just see the top of the ring safety,cause I think this is what im going to need to do to get the port timing im looking for.As far as the domes go,maybe I could use a stock head gasket as well then?Not sure how thin the o ring retainer will be machined for 85 mill flat tops? I was thinking a 2.5 with 2 stock gaskets would do it also,but it will be close to the ring coming out.I on a budget here so im stuck using stock cylin for now,this one has already been setup with big bore sleeves for freestyle use,but stock stroke,so 5 mill long rod will complicate things a bit.Im prolly going to send the entire motor off to chuckie for final porting to get it just right,I just need to do most of the basics myself getting this thing together with port timing in the range where its workable. I dont have a fortune to pay someone else to do it all. setup will be enhancer,rad flywheel,dual 48 carbs,bpipe,av100 fuel.I have no use for stupid $ flatwater back flip motors that wear you out in the surf,although I would like it to have enough linear power to pull backies on small surf.
wax.what im saying is that with the lower pistons I can drop the cylin down more with a thinner spacer without the pistons coming out the top past the rings,Every bit I can run the cylinder lower without this happening is effectively giving me lower transfer port timing correct?the thicker the spacer the higher the higher the transfer port timing will be. this why im trying to fig out what the max distance I can run the piston out the top so I can keep as thin a spacer as possible.do you think a 2.5 mill spacer will work with this setup and still have low enough transfer port timing to work well with freestyle use?I dont have degree setting for the new cylinder yet,will have that soon.the old 62t cylin Im dumping had a 7 mill plate with a 2 mill recessed head,its transfers port was 132 and the exh was 195 or so
mtrhead,sorry bud but i didnt think i even had to mention in the X it is going to be for freestyle/freeride use only
