OCD Solutions
- Rentz, GA
Is it plausible that a 46mm Mikuni would take the exact same jetting as a 44mm on the same boat? I just upgraded my carb and it would not run on recommended jetting, matched the same as the old 44 and it fired right up.
46mm jetting (Starting point)
125 Pilot
145 Main
1.5 N/S
27psi pop off
44mm Jetting (old Faithful)
120 Pilot
120 Main
2.0 N/S
17 psi Pop-off
733cc 61X with 165psi comp.
Lightened flywheel, Boysen Reeds
Sizzler Pipe
Ported Cylinder (for race unfortunately)
My old 44 was so corroded up I couldn't even get it open to rebuild it so i bought the 46.
125 Pilot
145 Main
1.5 N/S
27psi pop off
120 Pilot
120 Main
2.0 N/S
17 psi Pop-off
Sizzler Pipe
