- South Florida
I have a new WDK steering on the way and I am looking for a set of riser bars for it in the 31.8mm size. I'm starting to think that they don't exist. The least amount of sweep I can find is 6 degrees. I was planning on using the riser to adjust the length of my pole/steering a little bit but that is not possible if the riser bars have sweep to them and can only be mounted one way.
I have found some spacer pieces to allow the use of smaller diameter bars so that is an option too I guess but it defeats the purpose of the fatter/stronger/lighter/cheaper bars in the 31.8mm size that the steering was made for.
If by some miracle someobody knows where I can find some let me know. Hook a brotha up y'all.
