- Nampa idaho
This ski is a blast to ride and is ready to go. Can flip a boat wake with a talented rider. It is based on a yamaha superjet platform, so all superjet parts fit. This hull is very nimble it slides and rolls very well. It is a fiberglass layup.
Jet maniac 735 ported motor with 8 hours on total rebuild
Engine has even 180 psi compression and absolutely rips.
V force reeds
Ada high compression girdle head
Competitive crankshaft upgraded crankshaft
Oem yamaha electronics
Oem lightened charging flywheel
Oem yamaha 155 mm jetpump
Blowsion handle pole
Blowsion steering
Blowsion bars
Rad dudes 2.5 gallon slip tank
Factory b pipe
Jet maniac waterbox
Mikuni 38mm carbs jetted perfect for riding locally (idaho roughly 3000'ft)
Blowsion tornado air filters
New interstate agm battery
New starter
New starter solenoid
Just went through the ebox this week, fresh gasket on that.
Rule bilge pump on a dash switch
Primer bulb for carbs
I spent 11,000$ to build it and i will not accept offers.
The price is 9500$ cash only
Title in hand
986-888-4513 is my phone number
V force reeds
Blowsion steering
Blowsion bars
Factory b pipe
Jet maniac waterbox
New starter
Title in hand
