2015 RCW Havoc
For sale is my 2015 Rage Composite Works Havoc. It has been a freshwater only ski its whole life. Currently has 180 psi domes tuned with help from Kyle at Dasa, it runs great. Paint on the bottom has seen better days but the hull itself is perfect no stress cracks or delamination. Both cylinders have near perfect 180 compression.
-2015 Rage Composite Works Havoc Full Carbon
-House of Colors Lunar Yellow (Stickers can be removed)
-Dasa 865ss
-Dual Dasa 48mm Carbs
-RRP laydown exhaust manifold
-RRP ninja carbon chamber
- RRP water box
-MAXX 155 mag pump and skat prop
-Bored pump nozzle and Thrust Innovations trim system
-X-Metal handlepole
-RRP Steering System
-TRM Throttle
-FreeRiderz Quick start
-OEM Steering cable
-Blowsion bilge switch and rule 500 pump
-Professionally Turfed by Sanoman
-2 Gallon Kart Tank
-MSD Enhancer with lightened OEM Flywheel
-4 different head domes pending fuel and compression wants/needs. (Currently at 180 psi non ethenol 92)
-Billet Hood Latch
-Ratchet Strap for hood
-Pole Limiting Rope setup
-Thrust Innovations Pissers and Bilge Outlet
-carbon fiber ride plate and extra
Clean title in my name.
Asking 11,500 OBO
Located In Ellensburg Washington I can arrange shipping at buyers expense.
Comes with the trailer if wanted.
Pm with any questions thanks!
It was designed as a flat water ski but would say it's more suited for surf. I have flipped it flat water and it was really nice for spins buts the thrust trim was lacking a bit. If it had an ls 10 trim setup it would definitely do combos.
