2012 Krash Footrocket, RRP billet pole, Factory Pipe, complete driveline & electronics 701 set-up, Jet Lift Beach Cart
WTS 2012 Krash Footrocket Hull. This is a complete ski minus a running motor, 701 motor included (bad crank bearing cage). All you need is a motor rebuild, or throw in your own 701 based motor. All electronics & complete driveline are one season old. Hull is currently vinyl wrapped but is all black under the wrap. This ski rode amazing before the crank bearing started to go. Included with sale is a Jet Lift beach cart in like new condition, EZ Ski hitch hauler and all parts. Parts listed bellow.
2012 Krash Footrocket hull (Australian Built), hull is in very good condition, 2 season old hydroturf & vinyl wrap​
RRP Billet Handle Pole & pole bracket, RRP steering with Blowsion 0 degree bars, RRP throttle lever, with new Jetmaniac BB throttle cable, one season old new OEM superjet steering cable (07-08)​
701 motor (needs rebuild) complete with carbs, intake ,Factory b pipe, xscream waterbox, all plumbing and cooling lines, 2 season old new OEM superjet gas tank​
All electronics (one season old) complete rebuilt Ebox, CDI (protec modded), OCD Solutions surf armor battery cable kit, Jetmaniac Yamasaki OEM ignition coil, new OEM start/stop switch​
Complete driveline (rebuilt last season) Jertmaniac OEM midshaft w ADA coupler, rebuilt OEM 144 pump stator, Solas SS 144 wear ring, new SJ driveshaft, Hooker free ride 9/15 impeller, freestyle pump cone. Has a Blowsion tilt trim nozzle (trim cable needs replacement), worn 201 intake grate​
Jet Lift Beach Cart​
Located in Benicia California, I am asking $5,000 for the complete package, thank you for looking​
