- Ontario NY
Long story short I'm going to be on my 5th engine in my 2008 SXR 800. I've been having all sorts of problems, mostly since I put in a wet pipe and light weight fly wheel. I'm hoping someone can shed some light on my situation and let me know what I might be doing wrong.
Engine #1 Stock Engine- Engine compartment flooded and all Electronics were ruined. Dealer put all new electronics in for me under warranty. I then later threw a rod through that block after diving it under water.
Engine #2 Used Engine out of a 2004 SXR 800. At the time I installed this engine I also put on a wet pipe, and blowsion light weight charging fly wheel. I didn't notice much difference in performance. It did sometimes hesitate under full acceleration until I let up on the throttle and eased back into it. It later had the piston break apart.
Engine #3. Rebuilt engine by PWC Engine. I got the engine back in, and ran it for a break in and it over heated the head and pistons. (I missed hooking up 1 cooling hose, still can't believe I missed that). Sent it back to PWC Engine and they sent me a new one (Engine #4) under their warranty.
Engine #4. Didn't run that good from the start. Tried aftermarket flame arrestors as it ran better with the hood off. Didn't make much of a difference. Did some further research and realized my carb jets never got changed when I put on the wet pipe. I changed my main jets to the the recommended settings as well as changed my needles and springs.
Current settings:
Main Jets 152.5
Pilot Jets 80
Needle 2.0
Spring 95 g
Front Carb
High Speed 3/4 turn out
Low Speed 7/8 turn out
Rear Carb
High Speed 1/2 turn out
Factory Wet Pipe Screws:
Top 1/4 turn out
Middle- Closed
Bottom 3/8 turn out
Last year I ran these settings for a couple tanks of 32:1 to help break in the engine. Everything ran good except the plugs fowled up at that ratio. I took my ski out for the first time all season today and put 50:1 in it. It ran for about 15-20 minutes then the rear piston broke apart and forced parts of it out through the bottom of the crank case cover.
I thought for sure this whole time I was just too lean since I didn't have the correct jets in it. I'm puzzled why it blew up again today. Any thoughts or help would be appreciated. Attached is a picture of what the plugs looked like today after I got the ski back to shore. The left plug is from the rear (the cylinder that had issues)
Current settings:
Main Jets 152.5
Pilot Jets 80
Needle 2.0
Spring 95 g
Front Carb
Rear Carb
Top 1/4 turn out
Middle- Closed
Bottom 3/8 turn out
