kawa js550
Billy Racing
- Michigan
2007 Yamaha Superjet
Title in hand
170 psi even compression
Deka battery
Leak down tested
New 13/17 solas concord prop installed this spring
Primer kit
Good paint
Properly broken in motor
Only used premium 50:1 in the ski
Worx Extended ride plate
Westcoast intake grate
Blowsion handlepole spring
Good turf
Have handlebar cover/pad
Done last year:
Rebuilt 61x/62t motor
New crank
Top end rebuild with ProX pistons (81.50mm)
All new gaskets
New OEM crank seals
Carbs professionally rebuilt
T handle carb adjusters
Almost all new stainless hardware
All new fuel lines
Motor was sandblasted and painted with high heat paint
A lot of time and money has been put into this ski to make it reliable. Starts up with a push of a button, no choke or primer needed. The ski is tuned for straight reliability right now. I have it running a little rich right now just to keep it safe, but im sure you can get more power out of it if you lean it out some.
Located in Romeo, Michigan
Not willing to ship just yet
Title in hand
Deka battery
Leak down tested
Primer kit
Good paint
Good turf
Done last year:
New crank
All new gaskets
New OEM crank seals
All new fuel lines
