- Smith Mountain Lake, VA
On the 2004-2020 SuperJet dual Mikuni 38mm carbs, the adjustment screws are under the anti-tamper caps/plugs and recessed into the carb body. I understand that to install the extended T-handle screws, removal of the choke plates is required. I know that a lot of people install a primer, but I don’t want to do that. I would like to install some type of easy adjustment screws or cap adapters to tune my carb while retaining the use of my choke. Does anyone have a good solution for installing some type of easy adjustment screws while also keeping the stock choke? Could the carb body be easily cut/modified to allow some type of t-handles that wouldn’t interfere with the choke? Thanks for your help.
