I have a 2000 YZ 250, about 5 years ago I put a FMF Fatty and since I did that, the front mount and the mount at the back of the pipe by the silencer did not line up quite right.
At the time, I thought that it was just me, but 2 weekends ago I looked down to see antifreeze leaking from the water pump hose. The pipe mounts had broken and when I laid it over climbing a hill, the pipe moved down pinching the hose.
I ordered the new mounts and the hose to fix it, when I went to put the front mount on, there was about a 1 inch gap between the pipe mount and the rubber mount off of the frame, way worse than the first time that I installed the pipe.
Any suggestions?
BTW, one spring will hold the whole pipe on with no bolts at all, it just moves a little bit.
Any suggestions?
