chrisdoc0608
insulting
- rocky mount, nc
pics attached of piston wash. motor had a very lean wash when i bought it, i have now ran at least 2 tanks through it. 40:1 110 mix
ported 62t cases, 61x cylinder
33cc domes (190psi) .050 squish
46mm 140m 120l 2.0ns 95g spring (25psi pop) currently at 2.75 out on the hs
2* static advance & msd enhancer
coffman sizzler pipe
I know i need to go up in jet sizes, based on my piston wash would it be safe to say a 145m would be enough? The ski hit relatively hard, if i change the hs turns out any it boggs and if i go in any it hesitates. wot runs it makes a gargling noise which i assume is a lean condition.
I want this to be ready for wavedaze in two weeks so any help is very much appreciated
