1990 Superjet
1990 Superjet Jetworks Ported 701
2022-2023 fall rebuild
Blowsion bars
Blowsion steering
OEM start stop
Billet finger throttle
AC -2 Hand pole
RN aluminum water box
Factory B Pipe
OEM fuel line
Mikuni primer
Dual 38 Blackjack dialed by art for this setup
Jetworks modified mani
ADA angled reed spacer
V force 3 reeds Clean used
OE crank
Wiseco pistons
OE crank seals
Jetworks rebuilt top end and ported 701 2nd bore
New OEM starter
New OEM solenoid
Ada Girdled Head 35cc domes
JM clean used inspected bendix
JM Yamasaki coil, wire and boots
MSD Enhancer (2022)
JM new mid shaft
JM new solas mag pump assembled with jap bearings
new driveshaft
Jetworks custom “A” impeller
Worx 201 intake grate
Jet dynamics ride plate
Jetworks Bored 61x nozzle
Jetworks flow valve
Blowsion destroyers
Original turf
Never seen salt
Title in hand current registration
This boat is set up very similarly to Art’s personal ski. Runs amazing set up well and tuned. Art went through these carbs just last year. Very snappy. 93 pump gas. Lake Norman, NC
$6000
Will post pictures
Have owned the ski for fifteen years. This is the second time I’ve gone through and replaced everything. Cables, all new oe and msd electrical parts except stator and flywheel are original clean used oe parts. Never been wet.
Make offer. Will trade for freshwater sxr1500. Cash up depending on condition and handling mods.
$5500 accepting offers
Potential trades for tandem aluminum ski trailer, for two sit downs or one sit down and two stand ups. cash on your end
Freshwater sxr1500 stock motor, must be clean with or without handling mods, cash on my end.
