- Colorado Springs, CO
I have a stock 1989 JS550 with the only mod being a K&N air filter. I cannot get it to start unless I use fluid directly into the carb. When I get it running, it bogs down in the water and dies. When it is out of the water, it will start up with no problems.
Any idea as to what I should start checking. I am going to check the compression tonight, and order a carb primer kit tomorrow.
I ride at 5500 ft elevation.
I did a search and really could not find anything, so if this has been covered, SORRY!
Thanks!
Thanks!
