gj_fx1 said:I think if you have "around" a 5 psi range you need a better gage..
gj_fx1 said:Get a screw-in. I wasn't trying to be insulting, but you do always have to wonder about the gage and how the test was done when someone posts numbers that seem low. Two stroke especially the numbers are sensative to cranking speed, throttle open, how many revs you gave it etc.
Mark44 said:I checked my comp with two different gauges my new gauge was -15 pounds different than SXR Lou's gauge. You should check with another gauge.
You also need to check your squish angle to see where it’s at that is very important it may be too high and that’s why your comp is so low with that head.
Mark44
YEah, we checked the black one. The front cylinder had 80 and the rear cylinder had 95.Mouthfulloflake said:did we check my skis with it Dustin?
Mark44 said:Maybe the squish is about .125......................
Mark44
Mouthfulloflake said:if it showed that low on my black boat, its either a 40 psi under guage, or mine has detoriated since LOTO
Mouthfulloflake said:maybe he was joking!
I was drinking severly the day we checked them...
so it could have been 230 in hole, and 8 psi in the other.
:dunno:
Mark44 said::haha: :haha: :haha: :haha: :haha: :haha: :haha:
Mark44
PS:
"Ketsair eats worms also"
