13/16 cutback impeller for this engine combo
G
Goose
Guest
760 decked on the bottom to lower the port timing and ported.dual 44s,and r@d dry pipe msd enhansor and total loss later. i have a 13/16 straight blade impeller thats cutback how will that work with that engine for freestyle or should i get a concord thanks
G
Goose
Guest
above is the motor im building gonna have an msd enhansor for the begining of the year than switch to total loss in a few months
RiverRat
Louisville, Ky
It should work fine, however there are better impeller designs out there that may improve hood up over the straight blade. I think the 13/16 sounds good and if you cavitate it should be minimal......you are not going to sit an spin by any means
