1/2" PVC sheet for bench tops?
OCD Solutions
Rentz, GA
Anyone use the 1/2" PVC sheets sold at Home Depot for a bench top surface?
http://www.homedepot.com/p/1-2-in-x-48-in-x-96-in-White-PVC-Sheet-Panel-190360/205079515
I have been using 5/8" UHMWU sheets on my main bench for years now but it is warping and scared up from almost 2 decades of abuse. I don't have the "free" sources for it that I used to and can't justify spending the $800 it would cost to replace it with more UHMWU.
The PVC sheets are only $68 each and would be enough to replace both my existing counter tops.
Anyone have any experience with it? How does it stand up?
DAG
Charlotte, NC
Check out plastic-products.com we buy uhmw for our work benches and from what I remember they kicked everyone's ass on price. They are located right outside of Charlotte and I plan on driving down to Charleston for the eclipse might save you a trip.
Glory_Freestyle
Old, but still ridin'!!!
On my regular bench with the particle board top, I just resin it with the cheap home depot poly resin. Put 2 - 3 coats on it and it lasts a long time. When it starts getting scratched up and ugly looking, a quick sanding and another coat of resin makes it look good again.
OCD Solutions
Rentz, GA
Yeah, after using UHMWU, I can tell you right now, particle board and Masonite aren't going to cut it.
You'd have to use it to understand I guess.
Glory_Freestyle
I would definitely use UHMWU if I was really working on the bench like you do. Since my small bench is just a regular old cheap bench with a particle board top, the resin works well. Gives it some minor strength, doesn't soak in any fluids and is easy to keep clean.
OCD Solutions
Rentz, GA
That's my inclination but I thought I'd do some research and see about the PVC sheet first.
Still looking for somebody who has actually tried it out and can attest to it's physical properties.
OCD Solutions
Rentz, GA
Sure, I can do that again and probably will end up doing just that.
I'm still curious about the PVC sheet though....
Edit: Online research shows it may not be desirable for my application. It doesn't like heat, or to be "captured", So pretty much the same issues I have now plus a whole bunch or more weaknesses.
So, back to UHMWU it is. At least for the counter top anyways. I still have some fancy new plans for workbenches that would be much cleaner sheated in with with the PVC than plywood or OSB.
BruceSki
Formerly Motoman25
Long Island
What about steel or aluminum sheets? I did steel diamond plate and flipped it upside down for the benchtop so it was smooth. The backsplash to the bench got the diamonds going out though.
Sent from my iPhone using Tapatalk Pro
OCD Solutions
Rentz, GA
I have a bunch of 1/8" aluminum left over from my ski deck build but I really don't like working on metal. I had a really nice metal bench made at one time and ended up covering it in UHMWU.
The saddest part of all this is that I carried around full sheet of UHMWU for years before finally cutting it in half and putting it on my bench. When I moved to the US, I actually gave away the other half. The guy also got my steel workbench with the vise and all.
We use UHMWU extensively in our facilities so maybe I need to step up my game and see about scoring some more. The company discount should be significant!
