- Sweet Valley, pa
alright long story short a guy who happens to be a very good engine builder was over my house today and was checking out my ski. i told him all the stuff i was planning on doing to the ski. he started looking over all my parts to see where he could help and came across the fact that the water lines coming into the boat are only 3/8" of an inch. and with the bumped up compression i will be running, and porting and such he made the comment she will definetly be running hotter than it was stock. and i noticed that for a ski the sxr seems to run alittle warm. in the summer water temps where i am are mid 80's. my pump already has a bigger 1/4" NPTfitting from my factory pipe but the water lines inside are still 3/8". he said he will drill and tap my exhaust head pipe on both ends to accept 1/4" NPT fitting, thus allowing more water to flow through the motor.
do you gues think this is worth it, because as you know cooler motors run better, obviously to a certain extent.
you think if he does this that it will change hte adjustability of the water screws on my wet pipe?
it is not costing me anything to do so should i just go yeah do it?
