07 starter/bendix help
Hello. at the end of last season my super jet had trouble starting. It would take a couple tries before the Bendix would engage.I replaced the Bendix and now it won't turn the motor over. I check the starter it seems to turn over it just fine and hard. I've taken the flywheel on and off a couple times to make sure that it is lined up correctly. I'm pretty sure I can hear the starter spinning and the Bendix engaging but the motor wont turn over. Any help would be much appreciated I've taken apart and put it back together a few times and have the same result. also been testing it with two batteries of which both start my other super jet. thanks guys.
Have you tried removing the spark plugs and turning it over? Probably best to try by hand first, it should turn over easy with no plugs in.
