- Coeur D' Alene, ID
So I bought an 03 super jet with the full Riva RPM kit already installed. Has everything done to it but bore and total loss from what I can tell engine wise.
It has ran like a dream for the last 2 months and I have put an easy 30 tanks of gas through it. Today was the first time it has had any issues. Basically It does not like to idle, if I fall off it will die even with the key still attached. It also seems a lot more sluggish then usual from sub plane speed. Just does not have the pop like it did before.
I am not a gear head by any means but my best guess is either the oil mix ratio i have been using it fouling the plugs and I am getting less spark ( I have not checked the plugs at this point because I do not know what to look for) or I need to adjust my carbs or maybe both? I have run 2 pretty much straight gas tanks through it when i had run out of gas at the lake and had to fuel up at the marina. I am hoping those did not screw it up too badly. I mix the tanks at 50:1 as instructed by the guy i bought it from.
It is still very rideable but If i can get the low power back and a little idle that would be great. Thanks for your time guys this site has been a great resource for me.
