- scotland
Hi i have a problem with my octane bogging on bottom end,i recently purchased this ski, if i ski along very slowly then rip throttle fully open it falls flat on its face, the ski has 48mm novis and v force reeds, standard domes etc, i pulled the carbs off tonight and this is what i found, 2.0 n/s with gold springs 32psi??? pop off,130 high jets, 105 low jets, the high adjuster was 1 1/4 turns out i think thats ok but the low adjuster was 2 3/4 turns out this is way to far out i think, is it 1 1/2 turns max on adjusters then you need to re jet adjust pop off pressure, i think i need to go up to the next size of low jet is this the next step i should take? any help would be greatly appreciated thanks.:scratchchin:
