R/N pole on a square
surfgy45
just add gas...
San Diego, CA
or you can make your own if you have access to that kind of stuff, or know how to weld.
romack welded up his own like Pete. I designed my own and had it cut
...but yeah, its possible.:biggthumpup:
Mouthfulloflake
ISJWTA member #2
NW Arkansas
or do like I did, just drill new holes, and use the Roundnose Bracket too.
I would ad a shim under it so it sits closer to level though.
I had to grind my pole a bit to get it to go up high enough.
a simple piece of wood, glassed over would have changed that.
romack991
homebrewed
Warsaw, IN
wasnt the front of your pole cut off though? cause if its a stock pole there no way you'd get it to pivot high enough with the hood hooks inside the bracket area without one heck of a shim. :thinking:
cookerq62
Life's Been Good
Upper Bucks, PA
THe pole has that stop to save the cables from getting sheared. I was going pull my stop for more hight but the only time I have the pole that high is when I am wrenching or wrecking.
F
Freestyleriverrat
XFT round nose pole on square. Talk to Sergio or me about this one. He is making some changes for me to test for a lower profile.
joe b
depth tester
northfield, nj
Thanks for the input fellas:biggthumpup: It's for a friend who now has 2 ski projects & nothing to ride:frown: I gave my bracket & pole from my s/n to see if it can be made to work.
ANT
Just ride
What are you guys talking about with the stock steering cable? I did a conversion and didnt have to do anything to my cable. I used an AC pole, did I miss something..
guiness92
I put an xmw pole on my square and used the xmw roundnose bracket and it works awesome. I love the setup. Like other people said, the pole doesnt extend up as far as it should but it doesnt effect riding at all.
