280 lbs. 750sx-f build
knees better, it took about two days to start walking without a limp. i still can only bend it about half way because of swelling issues and i heve to do physical therapy crap:sadwavey:
as for the ski...
last night i cut out the second hole in the back of the hood and started prepping the pole for paint. I am also workin on makin one the thing circled in the pic.
and yeah, we got some snow lol
when you take out the stock bracket and put in a rn bracket its all open and ugly so that takes up the space that the oem bracket did and makes it smooth like it is supposed to
tbaer
USMC
BEAUFORT SC
he ordered a high roller customs pole. 40inch from bolt to grips. it comes with bracket, pole, chin pad, turn plate. straight bars, for $400 shipped. i also ordered the high roller pole a few weeks ago. the whole set up only weighs 4.5LBS and has a 100% replacement warranty!!!! http://www.highroller-customs.com/jetski
the Stock Kawi pole is HUGE and looks dumb!
even though he had the AC pole. The RN pole will look better as it is way thinner.
TRUE DAT:biggthumpup:
thinkin bout puttin the all my glass work on old for a bit. :shrug: probly just a week or sumthin cuz it is wayyyy to cold out in the garage without a heater, resin doesnt set up right, and i cant do anything in the basement without gettin yelled at lol so when i get my porting templates from jfw432 i'll port it, mill it, and get my enhancer in. hopefully there will be warmer weather coming up so i can start to put it back together so i can drool a month or two while the lakes are thawing out. lol
what color should i paint my engine? neon green, white, sumthin else? hmmm...
Waternut
Customizing addict
Macon, GA
Although today was ridiculously cold even down here, it's supposed to warm up again by Christmas.
I painted my engine yellow over the weekend and I think it looks good. Not sure how it would look on a light green ski though. A light blue might work for you though. If you look at my SN build you can see the yellow (daytona yellow) on my engine. My 750 build has pictures of the light blue (Ford blue) on my pipe. Both are engine enamels from any parts store.
N3vrSat1sfied
Military Member
Fort Worth, TX
looks good. well i think you should throw some paint on the inside.
Maybe do the engine compartment black or white. then paint your engine the green of the ski.
or color match the engine compartment green and paint the engine black.
I dont know what i am going to do My engine compartment will be neon green carbon fiber so my engine will probelly stay gray or become black
Waternut
Customizing addict
Macon, GA
Appliance epoxy for the win! White or black, it will look good and hold up even better. A few words of caution though... The paint is incredibly fine and likes to hover around unlike regular spray paint. This means is gets inhaled more (so at least use a dust mask if not a respirator) and it gets on everything within about 10 feet so paint outside. It will get on your arm too even if you're outside.
