CarFanatic
Fiberglassing Newb
- Cincinnati, OH
ok, so I started to put my ada head kit on and ran into trouble. The girdled studs, obviously one side has longer threads then the other. I assume the longer treads, go into the block?? I did the middle two first they went all the way in no problems. Then I moved on to the side, and man I cant get them in very far. I had to use vice grips to get two back out that I tried, thus ruing the finish on the stud... What is the trick to get these in all the way? do I have to tap the stock block again?? The middle ones went in real far, I assume they all have to go in that far??
