x-2 repower
Motorheads5
Livin the generation gap
ketchikan alaska
Check it out guy's I have the engine done just wanted to post a few pic's small pin 760, flat top's, welded crank,epoxy filled ported cases, freestyle porting, dual 40's,boyeseen reed's, 650 elect's, west coast head 28 cc domes, factory pipe b limited chamber,:headbang:
shawn_NJ
Chasing waves.
Daytona Beach
SWEEET motor. Thats super clean. Not sure what kind of compression your running (28cc sounds like it will be high)..... but if its low enough bump the timing up a tad. Really wakes up the small pin. My brothers running 160psi with a 7degree advance and it makes a HUGE difference off the bottom!
Motorheads5
ketchikan alaska
Yeah I don't know yet what the compression will be the number's on the w.c. domes are ep 7528 I was told the last two number's are the size feel free to correct me if I am wrong,
Motorheads5
ketchikan alaska
I thought you just removed some material on the cases for that .I guess either or huh?
this is the only one I have done however if I had the choice it sure is easier to machine the stator other than the cases and then you just tap the screw holes pretty simple.
OH YEAH and I am officially out of the factory pipe bidding war's good luck to all still in the hunt haha:stups:
shawn_NJ
Chasing waves.
Daytona Beach
Correct, on the last 2 ##'s. I had a 7500 series WC head that came on one of my 650 motors. I think I had 7530's installed, but I never ran the motor to see what the compression was.
Motorheads5
ketchikan alaska
I'm set at stock timing now I guess when I know my compression that will tell the story huh
Motorheads5
ketchikan alaska
by the way the westcoast head's take a gasket and o-ring's I just got mine from gordy at pacific jet sport's. installed it and ended up with 175 psi compression so in goes the motor I plumbed it for dual cooling
Crab
thanks darin...noswad!
Seattle
The head I am using is off a 95 sxi, I believe it had 28.2cc domes giving me 170psi with the porting I have, slightly raised exhaust and widened.
Motorheads5
ketchikan alaska
yeah I was happy at 175 psi I was reading alot of other stuff but ya know port height's and bores it all changes everything, hell this will be fine on pump gas on stock timing I think. I am wanting to try it like this anyway.
dbrutherford
Parts Whore
Fairmont, WV
blaster limited baby w/team scream stinger mod:1244::aargh4:
I would like to see a pic of that when you get it back. I may have them do mine since they are sorta close.
I sent my exhaust manifold and FP head pipe to Group K to get bored out. But they are in AZ and I am in AL...
