What do you think? Not grounded?
Whtbread
More Brap Please
south jersey
I have been trying to start a blaster that always ran fine last year. Now, I am trying to get it started and it never even sputtered. I pulled one plug out and held it close to the exhaust manifold to see if I got a spark. I got a spark, but it also started running on the one cylinder. When I pulled the lanyard on the start/stop switch, it kept running.
Do you think I have a bad ground or a problem with the wiring on the start/stop switch?
Thanks
I would check the two connections for the stop switch (black/white)
Unplug them, see if it starts without trouble.
If they don't have a good connection (or if the switch is bad) you can have trouble starting (and stopping)
Whtbread
More Brap Please
south jersey
I took the back plug out, got spark, but did not want to start. Kicked over, but no sign of wanting to start.
I had the front plug out before when it started.
Whtbread
More Brap Please
south jersey
I switched the plugs so that now I had the plug that was originally in the front cyl in the rear plug wire and arcing it. It started right up
So same as before then.
Right?
If you can, try a different coil. Or, cut back the wires a little.
Sounds like the coil isn't strong enough to support both plugs.
