Reference Library - replacement part numbers
michael950
for me to POOP on!
Houston, TX
It is important to patron retailers who support the sport, and there are many in your local community and nationally who make their presence known. However, we know it can take time for them to get parts from suppliers so I have compiled the following list with replacement parts and part numbers so you can get them for those last minute problems you encounter.
For parts you do not find in this thread, see The Official McMaster Carr Part Number List
michael950
for me to POOP on!
Houston, TX
UMI Steering part numbers, UMI rebuild kit, UMI Instructions
SuperJet:
Spindle Assembly Srews:
4 - Metric socket flat head machine screws - M6 x 1.0 x 21mm (not 100% on the length, but I think that is what I measured)
Thrust washer:
Size 7/8" x 1-7/16" x 5/64" (bore x od x thickness)
NTA 1423 - Qty 1 - Thrust Washer (5909K34)
Size 7/8" x 1-7/16" x x .030-.032
TRA 1423 - Qty 2 - Races
Bearings:
Bore 20MM, OD 42MM, WIDTH 12MM
6004-2RS (6661K87)
O-Rings:
DASH No's: 131 & 146 (& 113 for newer models)
Installation
UMI assembly illustration attached, and can be printed from instructions PDF.
If you still have problems view this thread: UMI Steering on 96+ SJ
When in a bind go to any bearing supply company and they should have what you need, otherwise support the companies involved in the sport and save yourself the hassel by buying a rebuild kit from Blowsion or Jet Ski Solutions (ckeck out JSS "Tuff Thrust" solution for the Thrust washer).
  • UMI_Instructions.pdf
michael950
for me to POOP on!
Houston, TX
Electrical Box Hardware - SuperJet '96+
Electrical Box Hardware:
Qty -- Size -- Desc -- Type --For
04 -- M6 x 1.0 x 16mm -- Pan-Phil -- Machine Screw -- Internal Parts (6 with stock CDI)
02 -- M6 x 1.0 x 20mm -- Hex Head -- Machine Screw -- MSD Enhancer
14 -- M6 x 1.0 x 25mm -- Pan-Phil -- Sheetmetal -- Cover - Might be 14x1... confirmed - SuperJETT
02 -- M6 x 1.0 x 30mm -- Pan-Phil -- Machine Screw -- Coil
There may be some differences between years, so be sure to confirm.
michael950
for me to POOP on!
Houston, TX
Pump Bearings and Rebuild
These are the pump bearings used in the WaveBlaster and SJ (96-04 / maybe to 06) pumps.
Blaster/SJ Pump Bearings
Stock bearings: Koyo 6205
For Sealed bearings use: 6205-2RS
Pump Cone:
O-ring 1-15/16"
DASH no: 133
Seal Dimensions:
25mm x 42mm x 6mm
Need 1 single lip & 1 double lip
michael950
for me to POOP on!
Houston, TX
WaveBlaster Accusteer System
The following part numbers are for the bearings used in the Accusteer WaveBlaster steering system. If you can, pay the difference for some Chinese Stainless bearings. With these bearings the cases are stainless and you can reduce the concerns about rusting of the bearing cases which will cause discoloring in the hull and the headache to clean and replace a rusty bearing.
Qty 2: R12-2RS [Dimensions: 3/4 x 1-5/8 x 7/16]
michael950
for me to POOP on!
Houston, TX
Replacement SJ hood seal
This is a replacement hood seal used by Slutty. He speaks highly of it.
Superjet Hood seal?
Seems like it can be used for a RN or SN. ( round nose or square nose )
Other options:
Most say to go OEM, some use Turff, or JetSkiSolutions also has a kit.
I will search the threads and update this post so you can research and make an educated decision for yourself.
michael950
for me to POOP on!
Houston, TX
ADA and Riva Girdled Head Hardware and O-Rings O Rings
When you do not have time to order direct from ADA Racing or Riva Motorsports, the following should work. Please note, M10 x 1.25 stainless hardware is very hard to find so it is often best to order direct from the manufacturer.
yamaha girdle hardware
M10 x 1.25: Qty Req - 6
Head Bolts
M8x1.25x50mm Qty. Req 10
ADA head bolts Note: this thread is not for the Girdle kit
ADA Hardware
ADA 701 O-Rings
701 Dome Base: #43
McMaster-Carr part # for Viton #43 o-rings is 9464K431
Buna:
Cord stock for outer seal 58" #9407K21
Dash 024 1 1/8" id #9452K78
Dash 020 7/8" id #9452K74
Dash 043 3 1/2" #9452K342
Riva O-rings
ADA 701 O-Rings
riva head oring sizes 701/760
Shell seal:1/16" Bulk Buna-N
From the top down:
Spark Plug:118 Buna
2nd :031 Buna
3rd :043 Buna
Compression chamber : 153 viton
michael950
for me to POOP on!
Houston, TX
Yamaha OEM replacement parts
Below are misc. OEM parts...
Replacements for the $20 Yamaha OEM fuel filter.
The Wavejunkies swear by them and can be found at any autoparts store.
Puralator F20004
Deutsch FF409
Fram G4169
Tygon Fuel line:
McMaster # 5552k24
michael950
for me to POOP on!
Houston, TX
Yamaha OEM bolts fastener and hardware chart
Superjet Bolts/Fasteners Charts
Bed Plates (14mm socket):
Sz8 - Qty 5 - M10 x 1.25 x 70mm (30mm threaded)
Sz8 - Qty 1 - M10 x 1.25 x 80mm (30mm threaded)
Sz8 - Qty 1 - M10 x 1.25 x 35mm (Fully threaded)
Starter:
Sz8 - Qty 2 - M8 x 1.25 x 40mm (25mm threaded)
Cases (12mm Socket):
Sz8 - Qty 8 - M8 x 1.25 x 85mm (25mm threaded)
Head (12mm socket):
Sz8 - Qty 10 - M8 x 1.25 x 50mm (25mm threaded)
Stator Cover (10mm socket):
Sz6 - Qty 7 - M6 x 1.00 x 25mm (Fully threaded)
62T Intake Manifold (10mm Socket):
Sz8 - Qty 8 - M6 x 1.00 x 25mm (Fully threaded)
Sz8 - Qty 3 - M6 x 1.00 x 35mm (20mm threaded)
Carb Flanged Nut:
Qty 2 per carb - M6 x 1.25
Coupler cover
Sz6 - Qty 2 - M6 x 1.00 x 25mm (Fully threaded)
(Sz = bolt size)
michael950
for me to POOP on!
Houston, TX
Cooling line and cooling fittings brass
Brass 90* fittings
1/8 - 27 NPT tap and a 21/64 drill bit
McMaster# 53525K16
Brass Tee fittings
3/8" OD
McMaster# 91355K48
Superjet Bendix Bushings
Brass bearing sleeve, 16mmx12mmx20mm
McMaster Part number 6658K16
Courtesy of this thread.
