32vickie
X-
- Pipersville, PA
A friend burned up the starter in one of my skis. While testing the system and trying to fine out if it was a bad ground, low battery we put it on charge for 5-8 minutes (10AMPS). At that time we heard a pop and the charger turned off. When we figured out that the starter was the problem we pulled the batter and notices it was leaking fluid. I am assuming we popped some type of overcharge safety valve. Can it be reset? Or sealed up?
Doug
Doug
