from uscomposites.com will the 4lbs kit work or do I need the 16lbs kit.
Thank's for the help.
Based off of their 4lb. density chart, you will probably need the 16lb kit.
Doug
4 LB Density Urethane Foam
Common Applications: This 4LB density foam is suited well for most flotation applications that require more support than the 2LB offers. This foam is recommended to be used when supporting gas tanks and some deck areas. Choose this density if you feel that the foam will be required to withstand minor to moderate loads. The 4LB density also works well in floating decoy or taxidermy applications as well as many other sculpting, casting, carving and other filling applications. More questions? [Try our Foam FAQ.]
Cat No. Kit Size Approx. Coverage Price
FOAM-0404 4 LB Kit 1 Cubic Foot $18.50
FOAM-0416 16 LB Kit 4 Cubic Feet $54.00
FOAM-0480 80 LB Kit 20 Cubic Feet $215.00
5 or more kits of the FOAM-0480 $205.00 / Kit
Product Information:
Free Rise Density: 4.0 lbs cubic ft.
Expansion Rate: Approx. 15x Liquid Volume
Buoyancy (flotation): 58 LBs per Cubic Ft.
*Physical Properties:
Parallel Compressive Strength: 90 psi
Tensile Strength: 110 psi
Shear Strength: 70 psi
Flexural Strength: 120 psi
