What footholds??? help
CarFanatic
Fiberglassing Newb
Cincinnati, OH
hmm, ok. revs seem to be the choice. Is there a pre cut turf kit for them? I know the other ones the have precut turf.
What do you guys use to cut the fiberglass?
Boris
The Good Old Days
I have been using my REVs since last year, love them.:biggthumpup:
Haven't tried the enclosures yet but a friend should have his done soon, he's mounting the enclosures.
Y
yamaslut
The guys running the REV's are you using the inclosed ones? or tht normal ones. I'd like a set that holds good, is comfortable but doesn't protrude to much into the tray, Its small tray to begin with!
no enclosures... I don't feel I need that
CarFanatic
Fiberglassing Newb
Cincinnati, OH
crap! 11x17 paper... I dont have a printer that does anything but 8.5x11:banghead:
man lookin at that build thread makes me nervous... I want holds bad, but... I no nothing about fiberglassing.
tor*p*do
Squarenose FTW
NW NC
Staples or Kinkos can do it. Most printers will do 11 x 17 if you go into the setup. All you need is the paper- it is just as tall as 8.5 x 11, just wider
This was my first install and I was apprehensive too, but it worked out fine :woot:
CarFanatic
Fiberglassing Newb
Cincinnati, OH
what did you guys use to make the cut?
How hard is it to glass them in?
What about laying the hydro turf. I know some foot holds have turf already cut.
What about the blowsions? THey have a turf kit already cut you can get aswell. anyone use them?
onesojourner
I use a thumb throttle.
springfield, mo
I have been out with my revs about 6 times so far. I love them. check out my build thread in my sig. they are very comfy. If I did it again I would put a little more padding on the top of the ankle cut out. look in the tech faq about turfing with out seems. don't do the pre cut stuff. do it yourself and it will turn out much better looking.
my rickters suck they hardley hold your toes in. i really want to ride more with xfts or try revs.so far the xfts felt better then 24/7s and my rickters.are the wcf rickter knock offs?
Squarenose
Gotta Getaway, HolyDiver!
I just ordered some Rickster footholds, kinda looking forward to cutting up my ski for some sick reason. I'm sure I can find some templates on here or PWCtoday. Just look for Rickster foothold template, right? Hope the feet fit, I wear a 14. Then, and only then...... with the quest for the barrel roll continue....
