1990 JS440SX
Keep an eye on those battery cables. I got mine from BatteryCablesUSA and the crimps were loose under the heat shrink. One fell off while riding. When I fixed it, I checked the others and ended up crimping and soldering on all new ends.
ATL
New fear unlocked.
ATL
OKAY
I felt horrible this morning. Had big dreams of going to SFF today. But didn't happen. Got all weekend for that.
Took ski out at the local ramp instead to test it out.
It did good! I failed to take any media. Unbelievable difference. Got it to do 46.3mph. Which is astounding given some issues I'll touch on. And it did maybe 38 or so before. Rode it back to back with a buddies stock 550... It's night and day. I'm wide open doing tail stands on the 550. This is just blips tiny blips of throttle.
Full disclaimer since buying this ski I haven't touched the 650 whatsoever, just some new exhaust gaskets. Haven't opened the carb nothing it was running solid with its dinky wrong impeller and cavitation station.
I expected
1. The load to throw off the tune
2. Impeller too tall 13/18 skat.
Trying to build motivation to swap in that 9/17 skat tonight but ughhhh. It wasnt that bad but definitely some fun on the table missing
Ski has 1 major new issue.... It is a spark plug murderer!! Running BR8ES, played with the high speed screw a bit and frankly landed a little lean judging by cameraing the wash. But it kept murdering specifically the rear plug real bad. Borrowed a knife from a random and trimmed back the rear plug wire which was baddddd. Absolutely no visible wire. That made it work for the rest of the day. But still after a short while plugs were shot. And it was a misfiry mess.
So I'm thinking @WFO Speedracer is right and I need to ditch the old booboo electrics. Maybe I'm just now asking too much of a tired old coil.
I Want more power so 750 is going in soon. Gonna try some br9eyas. Do a better cleanup of the wires and ride the SJ all weekend. Maybe just maybe this will come out.
Good to reap the award of the hard work.
Run BR7ES plugs or B7ES , the 650's , 750's ,900'S and 1100'S never liked 8's , we always had to swap them out or it fouled them out , I used to pull them out of brand new skis and swap them out they fouled out so bad .
Your wires may be shot but a set of b7es plugs and some non resistor plug caps will give it a boost in spark energy, it might be just enough .
Also I see you are running a stock 650 pipe, did you do the pipe mod on it , it will help quite a bit , do not expect huge power gains from where you are now running a 750 with a stock 650 pipe , you will be dissapointed.
ATL
Ugh running hotter plugs to solve problems just feels so wrong.
I run br9es in my 1100s no problems
Myself
manic mechanic
Twin Lakes AR
I also have always run the BR9es in Kawi's with no issues. The "all or nothing" swap ski I recently finished has already been ridden many hours on the same pair of BR9es plugs. Breaks in the plug wires cause the spark to have to jump a gap. The end result is LOTS of resistance at the discharge which shorts the plug. I'm guessing if you check those plugs you blew through they will read shorted from the top to the threads or hex.
ATL
Yeah I agree with this logic. It could be any combo of the coil and wires being shot honestly. I just trimmed them both back gave it some dielectric grease in the boots. See how it does tomorrow with br9eya & br7es (what O'Reilly's was able to get for the morning)
I'm all for fixing things correctly. Sure the wires are just clapped honestly... But all this 650 has to do is give me some fulfillment this weekend. It owes me nothing really. If it blows up on Sunday I'll be proud of it. Known good 750 + 750 ebox sitting on the shelf. End of seasons frankly already here. Really wanted to make sure the pump stuff worked and was worth it!
Loaded up!
As I said before BR8ES plugs were fouling out in brand new machines here , when I worked at the dealership , I serviced out a brand new ZXI 1100, I told the owner I needed to swap out the plugs in it, he said we are not doing that run what came in it , he has a warranty , I said fine but you get to deal with the customer when it boomerangs , about two hours later I see the customer pulling in with the yellow ZXI 1100 , the customer is steaming mad and as promised I went and got the owner to deal with him , I told the owner you want to get me that set of plugs now ?
In different parts of the country you can get away with running different heat ranges of spark plugs apparently , but here if you want to ride and not foul plugs you run BR7ES in Kawis , the Seadoos will run BR8ES plugs all day long with no complaints , they will also run on BR7ES just fine , you are right the wires are probably beyond shot , the only real way to know is cut them open and see , but what I suggested just might get you through the weekend, for sure it isn't a fix for obviously broken parts.
ATL
Did good all day on the BR9EYA's
Impeller still way off. Some stuffs way off. But hey it works does the best tail stands ever. The side holds are also impeccable for subs.
Until the throttle bracket sheared. Got it tigged back up by a buddy tonight for tomorrow though! Gonna loosen up the cable some more I guess and maybe wrap something around the grip. Throws definitely too short and I yanked too hard. Not great. Need to just order the right thing.
ATL
An update on this thing. I've been riding it putting tanks through it. Haven't touched a thing but feeding it plugs. Helene brought our water levels back up so enjoying that while I still can before pulling the 650.
Super stoked I can submarine this thing on demand now, tail stand on demand. Trying to figure out riding it backwards. A buddy laid down on his B2 and I successfully sniped him with a firehose. Best day ever.
ATL
Finally procured a pipe... Well I had a WC pipe, wasn't really feeling doing that again here. We're chasing power.
Coffman!
Immediately cut a step off the head pipe
It's a tight squeeze. Went to a more compact bolt and washer for the front left motor mount. May trim the bed plate a little.
I see I'm gonna have to drill and tap a fresh hole for the Lord mount.
I may end up cutting off the end of the stinger and rotating it. I see tons of people weld the chamber into 1 piece. I don't really WANT to do that but not opposed.
1000002923.jpgMy next big question is carbs. Motor is stock... Early big pin I think. It atleast has couch port timing.
I was planning to do dual stock Keihin 40s... But man I don't wanna play with keihins
I'd love for this thing to be fully ported, with SBN44's
Maybe that's phase 3
Look for a set of 40 Mikunis off of an SXR and the matching intake manifold . Those would be pretty much plug and play and run really well for you .
ATL
That's what is on my SXIPRO And they're kicking my ass
That's what I would like to run if I could find another set though.
Super tough to find
ATL
So my intrusive thoughts want me to just fully loot the running gear out of the SXIPRO.... Haven't convinced myself that's THE plan. So proceeding with what i got. It's a #22 cyl, early sx CDI with no limiter & r&d timing advance
Finally got a couch box to go with the watcon adapter. moved everything over from the SX box I got with this motor set.
Tiiiigght fit.
My 1 dilemma with this ebox setup is my bilge won't work. Which kinda sucks I'm depending upon it. Not sure if there's a better mount to explore. Or if I should just glue it down how I've done elsewhere.
ATL
Let's get back to it!
750 went in the Super chicken (which is sold now big sad)
I have another 750 I could piece together but REALLY not feeling it.
Enter this next chapter.
Rutland kit fits pretty damn good! I need to get the motor back maybe 1-2mm, may add a bigger washer to the driveshaft coupler to compensate or just hog out the bed plate a bit to shift it that little bit back. Nothing we haven't done before.
This is my 61x/61x that came out of the SN, it's just stock, shaved head, boyesen reeds. Gonna go back to a 44 on this. I just want this ski to work.
Big question is gonna be exhaust. My current plan is to run the 650sx Coffman pipe, mod it a little bit. With a 61x fpp style manifold (that I don't have and desperately need!) Stupid me had a Coffman manifold that went with the Jammer. There's a chance the center chamber mount would've matched up which would be amazing.... But I really don't want to spend the change on one to find out it doesn't. So what's likely going to happen is I fit whatever manifold I can get and just let the chamber hang off the head pipe and hope it holds on.
My other issue is cooling, I plan to run this single cooling but the 440 water fitting is tiny. I'd like to get atleast 2" of volume out of the exhaust and the stock rear exit ain't quite up to snuff. I'm tempted put in a stock side exit and tee them both to the waterbox. Sounds fun and functional.
I have another hull I really want to all out build with what I learn and develop in this hull. This hull looks awesome but it's got some feeble bits I'm not too stoked about, nor do I really like the rear exit. So trying to keep it simple for now.
Myself
manic mechanic
Twin Lakes AR
If you're keeping it simple then why not just bolt an adapter plate on and run a 650sx manifold and pipe?
HINT: ......a stock 750 manifold is actually slimmer than a 650 manifold giving a wee bit more clearance to the hull.
