Good couch for wife
Indiana
Hey guys! I’m looking at getting a fairly cheap sit down for my wife. All I’ve ever known are 550’s and Superjets. Work on everything and tear apart engines myself. Any recommendations for sit downs? I have ridden a 96 seadoo xp. That’s it. I know those are powerful and on the light side. There is also a 98 Yamaha GP 1200 for sale at a bargain. Just don’t know my way around this segment. How is it working on these compared to standups? Thanks so much!
ATL
assuming you want it to be 2T
Seadoo GTI or GTS 717 single carb 97-05 I think?
Absolutely tanks. Rotary valve motors idle like a dream
787 GTX 96-97 would be worth it if you want a little more juice.
If she's cools with the size of a GS/GSI/GSX. Go for one of those. They're basically 3seater x4's. Big fuel tank. They're a perfect bridge between a XP and a porker
1200s are labor nightmares. I'd avoid personally. The GPs have a little better access but an XL1200.... I cut the ski to remove the engine.
The Kawi couches are the most flimsy junk I've ever touched.
The Yamaha 2cyl couches are great but HEFTY. I mean asking alot out of a 701/760
I believe you are referring to 99 and later power valve engines in which case I agree , the 98 model however has a 65u non power valve engine in it , I also have to disagree with your evaluation of Kawi couches , out of all the brands I work on Kawis the least , they are damned tough .
To me the best recreational XP was the 95 model with the 720 engine, good well balanced all around ski , the Kawasaki Ultras are super fast and pretty reliable skis but expensive to rebuild , the Kawasaki ZXI series are also very good well rounded machines if you can find a 750 or one of the triples that doesn't have the CV carbs on it., they are also quite simple to work on .
I pretty much stuck with two man machine recommendations since the two skis you are looking at are two man units , if you want recommendations on three man skis LMK I can defiantly give you plenty of info on those.
West MI
gp760! I got one to flip but all the friends and family love it so I ended up keeping it. Does maybe 50mph, not tipsy and fun.
I bought a GP760 to part out, but it's so clean, I sat on it thinking one day I'd restore it. But I am not going to, honestly, so until right this moment my plan has been to part it out (i.e., pull the motor). If the OP wants a GP760 on a trailer with MI title, let's talk. Otherwise, damn it, now I am back on the fence about just gutting it vs getting it cleaned up.
ATL
I'm fully agreement on 95 XP 720 best rec ski period. Such units. Or the 96SPX which is same with slightly different exhaust and bits. I gotta point out again the GS/GSI... same thing but slightly heavier, more stable and wayyyy bigger gas tank
But no I'm speaking of 65u, there's a lot going on with them beyond the GP hulls they're a nightmare to work on, electronics are super unreliable and expensive (parted out 3 now), they're impossible to keep carbs working right they eat fuel pump check valves... Not to mention wrenching on 3 carbs vs 1. Just the amount of nuts and bolts involved is 2.5x what anything else is.
Just alot of wrench turning for the performance of a stock 787 Seadoo in a couch scenario IMO, and not any more reliable by any token of the imagination
The ZXIs I didn't find too bad, the hulls arent really fun though and super heavy. Couldn't believe how much stainless steel bracketry they have in those things. Id imagine a 650/750 unit would be ungodly slow. Servicing about anything in it also seemed misery beyond the motorset. Looking at you trim unit. Can't go wrong with 750/1100 though. A friend lately has being going through the ringer with an Ultra. Pricey parts.
WaveBlaster. /thread
If you will notice I didn't include anything with a Yamaha 800 or 1200 power valve engine , there are two types of Yamaha power valve engines , those that the oil line has come off of or the power valves have dropped and those that are about to have it happen , if any kind of decent mechanic did the work you won't know which unless it's an SBT engine which on these engines I cannot recommend .
In other word it's a crapshoot and at the same time a ticking time bomb unless the issues have been corrected already.
I don't think I have ever replaced any electrical stuff on one other than a starter here and there , a bunch of starter solenoids, but that's across the board on Yamahas and one stator on a ski that had the starter clutch blow up and destroy it , maybe you got a bad run of them IDK , but I can assure you it is not the case in general and I have worked on way more of the 1200 65Us over the years than I can count , in fact the 65U 1200 and the 760 are my favorite Yamaha engines of all time.
ATL
I don't think I have ever replaced anything ignition related on one other than a starter here and there and one stator on a ski that had the starter clutch blow up and destroy it , maybe you got a bad run of them IDK , but I can assure you it is not the case in general and I have worked on way more of the 1200 65Us over the years than I can count , in fact the 65U 1200 and the 760 are my favorite Yamaha engines of all time.
They put me through the absolute ringer. But the XLs specifically I couldn't fathom being a tech and being forced to slide the engine all the way to nose, take the hole hood assembly apart and pull it out. The 760/1200 are definitely the Toyota of the water, they'll never work 100% right I feel but they'll get you home with 2 cylinders down
The engine will actually come out without doing all of that but yes I agree they are not easy to get the engines out of either way , I can pull the top off one of those blindfolded by now , not that big of a deal really , luckily you won't have to do that very much , as on all Yamahas that are oil injected the oil lines do come off occasionally but as I said on Yamahas that's a problem across the board , I have seen it on everything from 701 VXR's to XLT1200 LTD's .
ATL
Really comes down to luck and budget. I fully expect at this point anything I buy with intentions of it working needs to be stripped down to the cranks seals as I'm nearly 30 and I need crank seals. Last 760 I had came to me running with 45&110 psi compression
Luck is defiantly a factor for sure , most of what I have been doing here this year is getting older skis that have sat for years running again , some have say 4 -10 years , I haven't replaced cranks seals on any of them so far this year and in the end they have all run out just fine , the only one that could even be considered a comeback was the STX 900 the guy refused to pay for a water test on , if you won't pay me to water test your ski then you are on your own , the only thing I can tell you without water testing is that it cranks and runs on the trailer just fine , I am a technician , not a magician .
@SteveC Photos?
@Captnem 2 cents from the smallest least knowledgeable peanut in the gallery here.
You understand 2-strokes.
You understand Yamaha 2-strokes.
Personally, I prefer to stay with one platform.
I am not a professional jet ski mechanic or a really knowledgeable amateur jet ski diy mechanic. So I like to keep things as simple as possible.
And although we do have some legacy Kawasaki skis from my wife's 1980-90's racing days, we are hard core Yamaha 2-stroke folks now.
Take a look at this write up about the Yamaha GP760 2-stroke and seriously consider starting a private conversation with @SteveC abpout his.
Indiana
SteveC where in MI are you? I’m in Northern Indiana. Interested in the GP760.
