- San Diego, CA
Working on a ski for my friend, it’s a 2003 Yamaha xlt1200 2 stroke. He bought it used and had a ton of corrosion in the crankscase and carbs. Got a new rack of carbs and wound up doing an sbt crank, pistons, and cylinders. We did an oil pump delete and ran 32:1 premix. Got it in the water and it ran for 20 minutes then blew a crank bearing and melted the middle cylinder. Got a new crank again, new cylinder, and new piston. Drained the tank and put fresh premix in. Got it in the water and ran great for almost 2 hours then lost compression on cylinder one and got some dimpling damage on the top of number 2 piston. Already have thousands dumped into this thing and I have no idea what’s causing this. I was leaning towards heat damage since I know it’s getting oil but with the dimpling damage I was thinking maybe an ignition timing issue. Any help is appreciated. Thanks.
