- Sacramento Delta
I am thinking about larger displacement engines and their carbs.
(Maybe a Big Bore JM781 for me of a 760 based big bore.)
Question: When do carb diameters need to be increased to handle the larger suction and larger fuel needs of a larger displacement cylinder/crankcase engine?
Given the Venturi principle, to keep the air flow moving fast, it seems that a smallest diameter carb which is capable of delivering the maximum amount of fuel needed for a particular size engine would be best.
And it seems that putting a carb which has a larger diameter than oem diameter carb on an oem sized engine would actually reduce air speed, and thus reduce atomization and thus reduce engine performance.
Also even if you do increase the cylinder size over oem, why wouldn't you just take your existing smaller diameter carb and increase the fuel jet size?
Isn't it true that for the same engine vacuum, the smaller diameter tube (i.e., carb would have the fastest airflow to the crankcase to the ports to the cylinder to be ignited, no?
Why did Yamaha engineers decide that a 61x 701 could best pull air/fuel from a single SBN44?
But each cylinder on a 62t 701 would best pull air/fuel from two SBN 38's each with their own dedicated cylinder?
How would putting two SBN44's or SBN46's on a oem stock 62t affect performance?
