Hello everybody!
I found a riva racing 7 ports cylinder, is it a good cylinder to do bouys with Superjet ? Reliability?
Thanks
Thanks
They are all the same...............Aside from the name on the cylinder and PV bosses, and sleeves, what kind of differences are there between say a Riva, R&d, and the unbranded Dasa (Lamey) cylinder?
Wasn’t the mod rule 785cc? 81x76. 783cc was max. Then superstock went 800. It’s been 24 years since Mod Class so maybe my memory has made an error?These were very popular race motors back in the late 90's Pro Mod days
I built a Ton of them! (as shown in my Avatar pic!)
Most all were +8m Long rod x 81.75mm Flat Top pistons
Which made 799.89cc Or fit perfectly into the 800cc rule at the time.
They were avail in both PV & Non-PV versions
Most all were run with the then R&D Dry Pipes, Total Loss, and 220# plus compressions
They were a Handful to ride!
As time went on, they became popular with the freeride / Freestyle crowd, and several strokes, and bore sizes became options
Anyway, Feel free to contact me directly for information on getting this going. Most parts are still available, except maybe sleeves?
Those would probably need to be made to order.
ski ya, Paul
Think he thinking of SS 800 limit. I remember at 2006 or 2008 APBA Nationals. Was talking with Pat Bogart. He said Chuckie built him a pissed off sub 800cc DASA. Said they took it right up to the limit!!!!!!Wasn’t the mod rule 785cc? 81x76. 783cc was max. Then superstock went 800. It’s been 24 years since Mod Class so maybe my memory has made an error?
The early Mod class with oem cyls was 785 as I remember it? When they started allowing aftermarket cyls it went to 800? Now im second guessing myself also? I keep log books on all that stuff and what I have built.Wasn’t the mod rule 785cc? 81x76. 783cc was max. Then superstock went 800. It’s been 24 years since Mod Class so maybe my memory has made an error?
Hey Paul, I think it was 785 and aftermarket cylindersThe early Mod class with oem cyls was 785 as I remember it? When they started allowing aftermarket cyls it went to 800? Now im second guessing myself also? I keep log books on all that stuff and what I have built.
when I get back from PCB races on Monday, Ill dig it out and confirm
P
I know near the end of MotoGP two stroke era all the 125/250 and 500 motors were square. Most 125’s are 54/54 today. I read the SAE paper Honda did after the end of the era and the data suggest most metrics (BMEP) the square bore produced the best results. I think every mfg that competed at the high level of Motorsport (MotoGP) was square. There paper is a good read. Honda releases a few real good papers on their two strokes at the endWhy is that?
What you talking about Willis?I know near the end of MotoGP two stroke era all the 125/250 and 500 motors were square. Most 125’s are 54/54 today. I read the SAE paper Honda did after the end of the era and the data suggest most metrics (BMEP) the square bore produced the best results. I think every mfg that competed at the high level of Motorsport (MotoGP) was square. There paper is a good read. Honda releases a few real good papers on their two strokes at the end
Heading towards the square bore. Such a better combination than the big bore we see these
Ok. Maybe a better way (layman’s) to say what I think the data suggest is.What you talking about Willis?View attachment 425193
